Scatter
  • Scatter
    Hi, I was wondering if anyone know of a simple scatterer like the one build into max, but that also supports map distribution, and also works outside the limit of 650000 objects that the max one have..
    I also used particleflow to some success, but ParticleFlow also seem to stuggle with alot of objects..
    I know about multiscatter and vray scatter.
    I am trying to distribute a lot of small boxes on an object. I have actually finished the project that I needed this for, but I am asking this for future reference.
    -thanks
    -Tom
    Forest Pack
    The free version might work for you. It is a good tool nonetheless and worth the purchase if you have a need of it.
    Ben Steinert
    pb2ae.com
      Thanks for the tip, The free version had some limitations, but it could handle obscene amount of boxes..
      It seemes that it only can use black and white images to distribute objects though (no gradients)..
      -Tom
        Perhaps spline definitions would work better in this case rather than density maps so that you can use the falloff paramaters?
        http://www.itoosoft.com/forestpack/r...ce/refarea.php
        Ben Steinert
        pb2ae.com
          Have you checked out Advanced Painter? I don't think it supports map distribution, but you can paint the objects where you need them, it might work for you if you're not updating the map. I also can't vouch for any object # limits as I don't think I've ever used it to that extent.
          http://www.scriptspot.com/3ds-max/sc...vanced-painter
            ive never had a problem with vray_scatter and i hear multiscatter is even better and has its own paint option
              Spooner:i know about advanced painter, and i have used it before... Its s great tool but not what i need here. I have decided to buy multiscatter, the client came back with revisions, they wanted the objects smaller, so i need to place Even more objects. Had a look at Forestpack too, but i felt that multiscatter fitted my needs better.
              -tom
