3dsmax 2012 Nitreous edit poly performace on high poly model still sucks for me
  • 3dsmax 2012 Nitreous edit poly performace on high poly model still sucks for me
    Crashes all the time if I try and soft select a high poly editable poly. Very slow when I just do normal selection of the model and try and move the faces/vertices !
    Regards
    Steve
    My Portfolio
    oh dear... well ive downloaded it, but wont have time to play for a couple of days... be a real shame if all the rave reviews were wrong.
      did you see Grant Warwick's review he posted about 2 or 3 days ago? Looks pretty good from there. He's using an i7 with a gtx295 and it looks pretty smooth.
      Kind Regards,
      Morne
        Im using an i7-970 with a gtx480. I can spin round the main model fine...and there are definite speed improvements there but as soon as I go into edit poly mode it slows right down.
        Regards
        Steve
        My Portfolio
          Finding a good graphics driver might be your solution. Not easy to do though, involves a lot of trial/error and restarts.
          Here is a resource I use to find drivers, I usually read the threads related to each driver to see if it is somewhat stable or not before trying it out:
          Guru3D
          Ben Steinert
          pb2ae.com
            Thanks. I'll take a look.
            Regards
            Steve
            My Portfolio
              or just switch to ATI. I never had driver problems with ATI nor have I ever heard anybody having remarks like you should be using driver version 37675.XXXX or whatever or revert from the new driver etc. or tweak the hell out of driver so and so
              Kind Regards,
              Morne
