weird rigging request.. scissors
  • weird rigging request.. scissors
    Ok this is weird one but i want scissors to walk on the tips of their blades. im used to normal legs. not straight things light this in a kinda hobble im the one usually figuring out some rigging stuff here but this one has me baffled. my brain must not be working today
    DOH! never mind. figured it out. so simple
      doh. never mind again. that didnt work out as i thought it would grrrrrr
        here you go:sc.zip
        will this work for you?
        Luke Szeflinski
        :: www.lukx.com cgi
          im on 2009. the file doesnt open
            sorry from 2011 the lowest I can save is 2010
            1. Create a point helper - add an 'Attribute Holder' modifier
            2. Open the Parameters Editor dialogue (Animation -> Parameter Editor) and add a new spinner with range 0 to 90
            3. Right click one half of your scissors and wire its appropriate rotation channel to the spinner value on the point helper.
            4. In the Parameter Wiring box set the direction to go from the spinner value to the scissor rotation value. In the expression box under the scissor side, add "degtorad" (without the quotes) before the name of the spinner. Click connect.
            5. Repeat steps 3 and 4 for the other half of the scissors only this time add a "-" before the degtorad in the expression box.
            6. Select the point helper and change the value on the spinner, the scissor halves should rotate in opposite directions.
            Luke Szeflinski
            :: www.lukx.com cgi
              but that doesnt make them walk? thats only good for making them open and close
                if you're talking about the walk on the tips of the scissors, make a bone from one tip to the other with an end bone. Make an ik solver from the bone to the end bone. Parent your scissors to the long bone object, then animate the main bone and the ik solver to make it walk along.
                http://joconnell.com/forums/scissors-Desktop.mov
                  That animation made me laugh. It's really cute looking.
                  Colin Senner
                    It's a bit like the walk you do when someone rings your house phone when you were on the loo.
                      how do i do it so my IK goal doesnt move away from the end bone? most i co do is align it back after i get the pose i need
                      my problem is when i move the main bone the end bone slides out of possition
                        this is brilliant, I really wasn't expecting a walk like that.. but it works perfectly
                          Kind of depends really, you either cheat and do it manually, make some sort of stretchy system that'll make the main bone follow the length of the ik and constrain one blade to the tip bone, or do some sort of script controller that'll limit the range of movement of the ik solver to a radius of the bone. Really you should have switchable pivots for this type of thing but that's reeeeealy complicated to do
                            ah ha!. no need to cheat. figured it out. Started with what you had but then went on my own tangent and turned out perfectly. once again here is another ELF tutorial with some help from joconnell. enjoy all
                            http://www.elfpro3d.com/Misc/rigged_scissors.avi
                            (xvid codec)
                            • #15
                              Good and sneaky - like it
