Backburnder strips: where are they saved?
  • Backburnder strips: where are they saved?
    I had a scene rendering via Backburner in 4 strips (because the render was taking insanely long - first two strips took more than 30 hours each). The next strip was almost done (like 27 hours deep) and my license server died, so I lost the whole thing
    (that is a major pain in the ass btw: can it be setup so the license server is only needed at the start of a render? Makes for a huge weak link in the process. This has happened to me several times before).
    Anyway, I'd like to salvage the image if I can but I can't find the first two strips anywhere. I've googled as well - where do the strips get saved from Backburner? Not in the render output directory and don't appear to be in my temp folder either.
    Any clues?
    /b
    Brett Simms
    www.heavyartillery.com
    e: brett@heavyartillery.com
    They should be in the render output directory - they've never been anywhere else for me. Within backburner it tells you where it's being saved under job details.
      Thats what I thought, but the directory was empty. I thought maybe there was some other default temp directory etc. Looks like I'm hooped.
      Thanks for the reply
      /b
      Brett Simms
        Are you using VRay VFB? It doesn't support strip rendering:
        http://www.spot3d.com/vray/help/150S...dex.html#notes
          I am using the VFB, I wasn't aware of the conflict since I don't really do strip renders it never came up. There were no warnings or errors that I saw and the first pieces appeared to render fine ( though it seems I should have looked for the actual files). Is that why they didn't save?
          Brett Simms
            I think so. Sorry I can't be more specific, has been a long time since I had this issue ...
              No worries - I really appreciate the help. I probably would not have found that issue without a *great* deal of wasted time
              /b
              Brett Simms
