AutoCAD - Esc Key not working to cancel command
  • AutoCAD - Esc Key not working to cancel command
    Hi all
    So couple of months back I came across this for the 1st time in AutoCAD 2011. You would start a command, then esc to cancel, but it wouldnt cancel the command. It seemed like an intermittant thing and was very annoying.
    So now I'm on AutoCAD 2012 and new pc and still getting same problem (intermittantly). Turns out, if you have any Adobe program open at the same time that it would "disable" the esc key. Closing photoshop or whatever Adobe program you have open, solves it.
    Very weird. Apparantly it is an intermittant bug and been there for years. I've just been lucky enough to only experience it the last couple of months.
    So now to fix it, is Autodesk to blame? or Adobe?
    Kind Regards,
    Morne
    Sounds like an Adobe thing to me. If for some reason the Adobe application is overriding/disabling keys that then affect other software. Very strange indeed since I use both a lot and have fortunately not run into this problem yet.
    Thanks for the heads up.
    Troy Buckley | Technical Art Director
    Midwest Studios
      Our architects, also have the same problem with 2011 and 2012 and don't use any Adobe application at the same time. It's really some strange issue.
      Daniel
      Daniel Santana | Co-Founder / Technical Director
      You can do it! VFX
      Lisbon/Porto - Portugal
      http://www.ycdivfx.com
