Buying New PC - Advice Needed About CPU and Motherboard and Videocard
  • Buying New PC - Advice Needed About CPU and Motherboard and Videocard
    Finally I will have a new pc.
    It will be a no-name, built pc and I have 2 proposals from 2 different computer shops.
    I am really bad about hardware knowledge and all the details so I would like to ask your opinions, your recommendations about parts or whole or any notice about anything.
    Here are the 2 proposals:
    __________________________________________________ ___________________
    PC1
    Intel Core i7 960 3.20DC 4.8GT/Sec 1366Pin 8Mb Box
    ASUS RAMPAGE III FORMULA DDR3 2xPCI-Ex16 GLan
    4GB DDR3 1333MHz CL9 Kingston (Single Modül) x 6
    Asus ENGTX460 DirectCU (256Bit)1GB GDDR5 2DVI HDMI
    1 TB SEAGATE 7200rpm 32MB NCQ SATA3 6Gb/s Hdd
    Raidmax MONSTER ATX WB BLACK 1.0mm Alumi. NO PSU
    PowerSupply FSP-700W Epsilon Active PFC
    1560 USD+ 18% VAT
    PC2
    CPU
    BX80623I72600
    INTEL LGA1155,Core i7-2600,3.40GHz,8MB Cache
    MAINBOARD
    P8P67-M-PRO
    ASUS SC-1155, HP67,SES,LAN,SATA,DDR3,USB 3.0
    RAM
    KHX1333C7AD3K2/8G
    Kingston HyperX 8 GB (2x4GB) 1333 MHz DDR3 Kit CL7 Memory CAS Delay Süresi CL 7-7-7-20
    HDD
    ST31000524AS
    SEAGATE 1 TB (1000GB), 7200 RPM, 32 MB Cache,SATA3,6 GB/sNCQ,
    VGA
    GV-N460OC-1GI
    GIGABYTE VGA 1GB FERMI GF GTX 460 GDDR5 3D 256BIT
    BOX
    AE-VXR-LE
    AEROCOOL VX-R LE Mid-Tower 3 Fan 14+2x12cm Fan Control 730W Box,
    1168 USD + 18% VAT
    VIDEOCARD:
    I am planning to buy :
    Gigabyte Nvidia GTX460 1GB 256Bit GDDR5 (DirectX 11) PCI-E 2.0 Video Card GV-N460OC-1G
    224 USD + 18% VAT
    What do you think?
    __________________________________________________ __________________________
    Is it better to have a motherboard
    - with 6 RAM slots- supporting 24 GB max
    - or 4 RAM Slots - supporting 32 GB max ?
    But I hear that there are not any 8gb memory modules at the moment. And it make take 1-2 years for they arrive to my country.
    I am confused which one to choose.
    I will be very thankful for comments.
    Cheers everyone
    for my blog and tutorials:
    www.alfasmyrna.com
    Pixela,
    Some thoughts, not having investigated the specific hardware.
    Top down, most important components to least:
    CPU:
    I'd go with the 2600K, which seems to be outperforming almost everything. http://www.anandtech.com/show/4083/t...-2100-tested/1
    It has hyperthreading and allows for very modest (and it mentions easy) overclocks at 4.4ghz all on air cooling.
    MB:
    Love Asus, no suggestions there. If you're planning on doing a multi-gpu setup, get a motherboard with multiple x16 lanes for the cards, note: I have 2x GTX 460s and they make my case EXTREMELY hot because of the configuration and how close they are to touching, all newer Nvidia cards run much cooler than the GTX 460s, if I could suggest a newer one .
    Depends on how much ram you'll be putting in it . Some MBs have different configurations (dual channel/triple channel RAM), which is why some have 6 slots (triple channel), 4 slots (double), but I believe there isn't a performance difference, just a maximum amount of RAM.
    How much RAM do you need!?! 24GB is fine for 95% of (3d) users imho.
    Be well!
    -Colin
    Colin Senner
      My dream machine specs are:
      Asus MAXIMUS IV EXTREME REV 3.0 mobo
      p2600k cpu
      crucial ram
      seasonic x-850 PSU
      EVGA Geforce 590 GTX
      Luke Szeflinski
      :: www.lukx.com cgi
        Thanks for replies These are very helpful feedback for me!
        Originally posted by MoonDoggie View Post
        Pixela,
        Yes please suggest newer ones as well and I can check if it is sold in my country or I can check the price.
        About RAM: Yes at the moment I have 8GB RAM and feel that 16GB (4x4GB) will be great at the moment. More RAM means that I can put more detail (more poly's , objects, textures etc) in my scenes. Few years ago when I had my pc, I thought 8GB will be adequate and it was for long time. But every year my scenes get more detailed and eating RAM. I can't upgrade my pc frequently so I must use this one few years. So who knows 16 GB will be adequate in few years? If the 8GB ones are in the market in a reasonable price in few years, then I can have 4x8GB or I must choose the 6 slot Motherboard and have 24GB now.
        www.alfasmyrna.com
          hmm...I'm still using 8GB. But most ram sticks are 4GB so on 4 slots max you can have nowadays is 16GB. But also the mainboards are ready for 32 so it's just matter of time when 8GB sticks show up. SO I think for now 16 is enough and when 8GB sticks show up you can just swap it.
          Luke Szeflinski
          :: www.lukx.com cgi
            Yes I thought the same. Now 16 GB will be great. And in few years, I can make it 32 GB.
            Because the CPU in the 4slot Mainboard seems to be better than the other one.
            www.alfasmyrna.com
              And cheaper !!!
              Luke Szeflinski
              :: www.lukx.com cgi
                The Kingston HyperX RAM have a great CL7-7-7-7 which means it's fast. You should also make sure they are matched kit (which they probably will be).
                Don't forget your CPU aircooling, make sure that is a quality fan that is quiet.
                Same goes for the case, I have x2 of these:
                http://www.fractal-design.com/?view=product&prod=48
                they are very quiet, even if you had a couple of their fans on the front intake, which will give you more than enough cooling for a bit of overclocking. They are also cheaper that some of the more branded boxed, honestly they great some great reviews too.
                http://www.tomshardware.co.uk/rv02-e...w-32201-4.html
                Simon
                I need a new signature
                Max2017.1 | Vray 3.70.01| win11
                ASUS Z790PLUS | i9 13900K | 64Gb RAM | Geforce GTX4070Ti
                  Yeah for CPU cooling in my opinion the best thing is: Thermalright Venomus
                  http://www.thermalright.com/products...t_id=27&id=177
                  regarding cases anything form here: http://www.silverstonetek.com/produc...tower&area=usa
                  Luke Szeflinski
                  :: www.lukx.com cgi
                    Thanks for all these tips guys.
                    So do you think the i7 2600 cpu is the best one in that price range?
                    www.alfasmyrna.com
                      Originally posted by pixela View Post
                      thanks for all these tips guys.
                      no question about it !!!
                      the best thing since sliced bread
                      But if you buy it and you won't be happy , you can always give it to me
                      Luke Szeflinski
                      :: www.lukx.com cgi
                        Very glad to hear this!
                        And as clear as it can be for a hardware dumb like me!
                        www.alfasmyrna.com
                          Guys one more question:
                          RAM:
                          CL7 1333 mHz
                          or
                          CL9 1600 mHz?
                          Which one should I choose?
                          I heard that they are better when CL value is low and mHz value is high but can't find anything that has both specifications. These are the ones I can find on the market.
                          www.alfasmyrna.com
                            The difference between them is so small that I dont think you will notice it much. Maybe couple of seconds on a large render.
                            Kind Regards,
                            Morne
                            • #15
                              Thanks DVP3D.
                              Now another question:
                              My current PSU is Silverstone SST-ST75ZF 750 Watt.
                              New one will be Absolute 1000W 80+Certified.
                              Is this ok?
                              www.alfasmyrna.com
