3dsmax loading image sequence does not load all frames
  • 3dsmax loading image sequence does not load all frames
    Is there a reason this is happening ? Its not a memory issue as I have 24gb on my system and its a very simple scene.
    Regards
    Steve
    My Portfolio
    Are you sure there isn't one frame missing or mistake in naming number?
    Luke Szeflinski
    :: www.lukx.com cgi
      I don't think so as all the frames were output from aftereffects with sequential names..I decided to use avi instead now though as I haven't got time to work out what was wrong with this method.
      Regards
      Steve
      My Portfolio
        do you try to load the images in max ramplayer? there was a memory thing at 2 gig. the ram player just stops loading after that limit..
          buy pdplayer!!!! ramplayer is terrible
          show me the money!!
            Well, that's one solution But I don't want to have to fork out money for something I only use very rarely...plus it should work, and if it's not, then there will more than likely be a way around it
            Regards
            Steve
            My Portfolio
              It seems the format needs to be quite specific for max and ram player to be able to read the sequence correctly. Check this out if you are interested: LINK
              Regards
              Steve
              My Portfolio
                Make sure you that aren't just telling Max to open an incomplete .IFL file. Select the type of file you specifically want to open and have it create a .
                - Geoff
