Hotfix 2 for 3ds Max 2012 and 3ds Max Design 2012 is available
  • Hotfix 2 for 3ds Max 2012 and 3ds Max Design 2012 is available
    http://area.autodesk.com/blogs/maxst...2_is_available
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    thanks for the heads up
    Kind Regards,
    Morne
      how about BB, is it working?
      show me the money!!
        I'm not touching BB 2012 with this crappy ipv6 (can't make it work !)
        Luke Szeflinski
        :: www.lukx.com cgi
          Are you guys using 3dsmax 2012 in your work pipeline now ? Is it stable after the SP1 and HF2 ?
          Regards
          Steve
          My Portfolio
            I am, and it is very stable. I had some graphics issues, but they have been resolved.
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              what did you do with the BB thing Bobby? how did you make it work? are you using BB 2011?
              Martin
              http://www.pixelbox.cz
                I use the V-Ray's distribution renderer.
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                  Maybe I have missed something, but what's the problem with BB2012?
                  It works just fine for us here in the office. I didn't make any changes to our configurations. I get a couple of warnings, but I was told I could ignore them.
                  I guess since I haven't had problems, I never really looked to see if other were having issues or not.
                  Any links to anyone's specific problem I would definitely look into it?
                  Troy Buckley | Technical Art Director
                  Midwest Studios
                    You cant do the same kind of thing with Vray DR as you can with BB. I use the new version of BB but haven't tried implementing the ipv6 protocol. It works fine for me just using the standard protocols.
                    Regards
                    Steve
                    My Portfolio
                      I couldn't make it work because of ipv6. Not only got errors but couldn't connect to manager and other computers.
                      Luke Szeflinski
                      :: www.lukx.com cgi
                        How you can use bb2012 with ipv4? I though it only works with ipv6!
                        Luke Szeflinski
                        :: www.lukx.com cgi
                          It works with ipv4 but you must disable ipv6 dhcp in your server or it will only work with ipv6 and if the network (routers) isn't fully ready for ipv6 it will give a lot of headaches.
                          Daniel
                          Daniel Santana | Co-Founder / Technical Director
                          You can do it! VFX
                          Lisbon/Porto - Portugal
                          http://www.ycdivfx.com
                            as far as i know vray doesnt even support ipv6 or does it??
                            Martin
                            • #15
                              I can only network render with the firewall completely disabled.
                              Reflect, repent and reboot.
                              Order shall return.
