max 2012 uses a lot of ram
  • max 2012 uses a lot of ram
    I have the same problem like jsrocha wrote on thearea.com but the guys from autodesk are sleeping. maybe somebody could help me.
    I think I found the problem, I’m looking for a fix now. Be right back…
    edit:
    The problem seems to be, indeed, thousands of notes tracks. Check the attached image:
    The left track view is from a fresh, clean scene, from a just opened Max.
    The right track view is what I get after merging anything from your scene.
    I tried to delete the whole ‘Max MotionClip Manager’ node, using
    Code:
    [COLOR=#0000BB]deleteTrackViewNode trackviewnodes[[/COLOR][COLOR=#FF8000]#Max_MotionClip_Manager][/COLOR]
    but it’s not a node, but a controller. I don’t know how it got there, but there should be a way to get rid of it with a script. Since I’m a little short of time, I’ve just stopped there, but let me know if you can’t fix it, I’ll take a look today after work. Probably if you can post the script you used to clean the problem before, I can take a look at it.
    cheers!
    M
    3D Studio R1 (DOS) -> 3DS Max 2012
    from Montreal, QC - home of 3ds max
    thanks a lot
    best regards
    themaxxer
    Pixelschmiede GmbH
    www.pixelschmiede.ch
    Check this thread:
    http://www.chaosgroup.com/forums/vbu...393#post429393
      thanks codi for the script. but it doesen't work, because have over 24 million notes and the script doesn't seem to work with so many notes to delete.
      is there another way to delete the notes?
      I am very frustrated because I have to remodel everything from scratch.
      thanks for helping.
      best regards
      themaxxer
      Pixelschmiede GmbH
        Mmh, maybe "deleteTrackViewController <maxtvnode> <controller>" could work but I can't test it, could you send me a sample file with some of these notes?
          maybe somebody has an idea to delete the nasty notes...!
          here are the scenes: http://www.pixelschmiede.ch/download/notes.zip
          thanks for your effort.
          best regards
          themaxxer
          Pixelschmiede GmbH
            deleteTrackViewController seems to solve the problem, could you try this?
            Code:
            deleteTrackViewController trackviewnodes TrackViewNodes.Max_MotionClip_Manager
            To be sure it works, run the script, save, exit max and reload the file ... I don't know if deleting MaxMotionClipManager will break something in the scene.
              hey codi you're the man!!!!!! many thanks!
              it's working and it doesn't seem to make problems.
              if you pm me I would like to reward your help.
              thanks so much.
              best regards
              themaxxer
              Pixelschmiede GmbH
                You are welcome, knowing I solved the problem is enough reward really
