TXT map list
  • TXT map list
    Is there a way to create a .txt file of all the maps that your scene?
    - Geoff
    doesn't MAX's archive feature do that for you?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
      Hmm. Dunno. Never used it. I'll check it out.
      - Geoff
        Actually, that only makes a list of the files that it found. I want to generate a list of all the bitmaps Max can't find. Basically I just want to make a txt file of the Asset Tracker.
        - Geoff
          Or even just list them in the Listener so that I can paste it into an e-mail.
          - Geoff
            Run this piece of crap:
            Code:
            MyOutFile = "c:\\scene_texture_list.txt"
            ThetextFile = CreateFile MyOutFile
            local mapfiles=#()
            fn addmap mapfile =
            local mapfileN=mapfile as name
            local index=finditem mapfiles mapfileN
            if index == 0 do append mapfiles mapfileN
            enumeratefiles addmap --line 9
            sort mapfiles
            for mapfile in mapfiles do
            	format (mapfile as string) to:ThetextFile
            	format ("\n") to:ThetextFile
            Close ThetextFile
            ShellLaunch (MyOutFile as string) ""
            Based on an example in the max help.
              Thanks John. That gives the same result as the Archive thing, though. :/
              Man, I never thought this would be so difficult.
              - Geoff
                Colin Senner's Relink Bitmaps script will print a list of missing texmaps for you. I'm fairly sure it will also pickup Vrmesh files and things like that, but it will track the *missing* images for you anyway.
                /b
                Brett Simms
                www.heavyartillery.com
                e: brett@heavyartillery.com
                  ATSOps.ClearSelection()
                  atsarr = #()
                  ATSOps.Refresh()
                  ATSOps.GetFiles &atsarr
                  for atsfile in atsarr where (ATSOps.IsInputFile atsfile) == true do
                  if (getFiles atsfile).count == 1 then
                  print ("found: " + atsfile)
                  else
                  print ("missing: " + atsfile)
                  But it only works with absolute paths not with relative.
                    Ah sorry, didn't read the second line where you mentioned missing:
                    Code:
                    local mapfiles=#()
                    fn addmap mapfile =
                    enumeratefiles addmap #missing --line 9
                    sort mapfiles
                      /b
                      i second this
