Dumb animation question - can you 'disable' animation?
  • Dumb animation question - can you 'disable' animation?
    I have a few doors and things that are animated (opening doors for instance). Is there a simple way to temporarily 'disable' the animation of these objects within Max 2009? I only need the doors to be animated in certain camera shots - not all of them.
    Kind Regards,
    Richard Birket
    http://www.blinkimage.com
    maybe put the doors in a layer called "animated". then duplicate them and put the duplicates in a layer called "un-animated" and delete the animation from that one
      Use a Rotation List controller insted of the standard controller. It will automatically add the standard controller as first in the list. You can then turn it on/off using the weight spinner.
      Regards,
      Thorsten
        yeah. thats what i meant lol
          I've discovered Animation Layers which seem to help. Saves duplicating geometry.
          Kind Regards,
          Richard Birket
