post with rope
  • post with rope
    Does anybody have anything like this (post with rope) they can share, or point me to a place I can purchase it? I looked, but I couldn't find anything.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    should be simple with two cylinders for the posts and a spline wrapped around them
      I tried, but I wasn't getting realistic results. I will give it another college try tonight.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        were you using displacement maps or bump maps on the rope to make it look more realistic? good rope textures should sell it
          http://www.3dknot.com/files/images/2010/01/image014.jpg
            Easy enough really - to make a rope you need to use two helix splines as your weave and then path deform them along another spline for the actual direction of your rope. Either that or just use a normal spline for the rope, and then use a heavily tiled gradient ramp rotated 45 degrees off axis. Or use elfs map and stop wasting time doing things the long way around
              http://www.3dknot.com/tutorials/3dsm...-rope-texture/
              if you want to do it the hard way
                here's my attempt at a post with rope.
Name:	light house - se.jpg
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                  little far from the post but looking good
