How do you guys get around stuff like this when lofting. I usually use lofts when working on swimming pools
Lofting errors
I have found sweep to work a little betterBobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090
- ​Windows 11 Pro
I rebuild it by hand, which can be a royal pain in the a**
Another way could be to extrude your spline, convert to polys, add a shell modifier whose depth is the size of your pool border, convert to polys, delete everything but the top faces and use that to build your border.
There is a chance that it would cause the same problem but worth a try as it takes five minutes.Check my blog
Yep, Colin is right. There are too many verts in that corner which is causing all of the problems.
For lofts, I tend to use the two verts at the corners of the arc and then use the bezier handles to do the rest. Then all you have to adjust is the subdivision amount of the loft. I am not sure of the terms used since I am not at a computer with max on it right at this moment.
The other thing that I do when I have these types of issues with tight corners is to make the spline be on the inside instead of the outside. I tend to get better results that way. Simply outline the spline will usually get me most of the way there.
to be honest that corner is the easiest to fix. ive got two corners like this
Yep! That is the exact situation I was referring to. By putting the loft spline on the inside of the shape instead of the outside, the loft shape will not have to collapse into itself to make it around that tight corner.
actually on the clients blueprints. the outer curve is supposed to come to a sharp corner but on the inside curve have the rounded corner. actually while i was spending time thinking how to do this i lost track of the big picture. those corners are actually going to be covered so you will never see them.
