I want to be able to zoom into the camera viewport when I have an image set to the background - is there a script or something that does this and keeps the image and model locked together ?
Changing the focal length or film gate wouldn't work - if you imagine lining up a photomontage in the camera viewport.
Thomas, thanks for the link unfortunately we are using max 2009 !! Just my luck ! Did you create this ? If so, do you have an idea of when you will write one for 2012?
Thanks
N
EDIT: Ok, I can see it was Peter Watje that wrote it, I might contact him.
Actually having tried the plugin further I really need to zoom into the Viewport Background image with the model locked to it - almost if I was zooming into an image in photoshop, if you know what I mean ?
i dont know if it still works, but when using opengl, you can do what is called "virtual viewport" - actually pretty positive this works in 2009, as i used to use it for cam alignment. autodesk in their wisdom discontinued the feature in their switch to direct 3d.
controls below:
/ (numpad)
Virtual Viewport - to magnify a portion of your view without changing the camera (OpenGL Modus only)
no problem.. what comes from being a dinosaur i guess. i dont think even the guys at autodesk remember that feature. its not in the help files for max any more.
