Very off topic, but I know there is a ton of expertise around the forum and hoped to get some tips:
Started yesterday with Photoshop crashing Windows out (Vista 64). I got a totally garbled screen and was unable to access anything even though the OS was still up in the background somewhere (still alive on the network for disk access).
I thought it might be a video card problem, or a RAM hardware issue. I updated my video drivers, and still had the problem. I've run Furmark several times for a 1/2 hour or more, and run Windows Memory Diagnostics and found no problem. I swapped out all the RAM chips with another machine and it's still happening.
I thought it might be CPU heat or something, but I ran Prime95 for 45minutes with no issues. then I ran Prime95 *and* Furmark at the same time and still no problem (although I think I caused a brownout in my neighbourhood while that was running
Any ideas of what else might cause this kind of thing? Everything I read points to RAM or GPU but they both seem to test ok.
Thanks in advance/b
Thanks in advance/b
