View-port materials
  • View-port materials
    All of a sudden I can't see my materials in the viewport. I changed to opengl, directx, and nitrous, but nothing. Help!
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Odd.... It seems my color correction material broke. When I re-create the material things start working again.
    Bobby Parker
    phone: 2188206812
    • Ryzen 9 5900x CPU
    • ​Windows 11 Pro
      You can try to disable/enable the "show texture in viewport" option in the map that you want to see in the viewport a few times to see if it clears any conflicts with other maps in the material that may have it enabled.
      EDIT: If the problem is with more than one texture check the "Display" tab in the command panel make sure that shaded mode has "material color" selected.
      Ben Steinert
      pb2ae.com
        I tried that, but it didn't help. The only thing that helps is re-creating the textures.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
