Slow machine/formatting?
  • Slow machine/formatting?
    Hello All!
    need your suggestion guys.. from past 1-2 months i am feeling as if my PC has became very slow.Few problem which i am facing-
    - long time to open 3ds max ( i am using 3dsmax 2011 & vray 2.0 )
    - long time to load file ( file size around 80 to 100 mb with reasonable number of proxies)
    - Lots of PF usage in task manager after file is loaded & pc almost freezes ( shows 2gb even with small file but with some files it goes even upto 6 gb!)
    - long time to close max. Even after closing max it shows in taskmanager process list as active & takes time to completely get off
    - Even when 3dsmax is closed, windows explorer takes some time to browse.
    PC Config- PC age is 2 years, i7, 4GB ram, 1 GB nvidia GCard ,Windows XP 64 bit , sufficient space in C drive
    My QUERIES-
    -Is PC slows down after being used extensively for 2 years ( on an average 4-5 hours of rendering per day )?
    -Do i need to format & reinstall windows to make is work like earlier?
    -Do i need to adjust virtual memory/ pagefile ? right now it is system managed.
    -I generally use vray proxy for trees, i use 7-8 types of trees as proxy & spread them in my scene. Is PF usage dependent of how many different types of proxies i am using in my scene?
    I am fedup.. i dont want to unnecessarily format my machine.. reinstalling everything again is a pain in a** i am about to start on a big projects.. will be difficult to work with machin in current condition.. Help guys!
    Prateek Vishwa
    sigpic
    www.prateekvishwa.com
    https://www.facebook.com/pages/PVDS/161239543925007
    Windows tends to get slower with time indeed. One reason I have found for this is the fragmentation of the disk space; usually running the Windows defragmenter may return some of the speed back. I found also that with time, Windows need more and more memory (I don't know why). For example, our build machine (which runs nightly builds of V-Ray every day) worked fine and fast with Windows 7 and 2 GB of RAM just fine. After a year or so I noticed that it swaps constantly to disk (without any additional programs installed in the meantime, and regular disk defragmentation). Adding 2 more GB solved this problem for the time being.
    All in all, most people I have talked to agree that Windows machines just need to be reinstalled after a while In your case, if you have never defragmented the disks of your machine, it might be worth trying that first.
      It also helps to use a SSD for the system disk. It helps greatly. I love my SSD.
      I'm sick when I'm using someone else's computer and programs take forever to start, even the internet browser.
      Marc Lorenz
      ___ ___ ___ ___ ___ ___ ___ ___ ___ ___ ___ ___
      www.marclorenz.com
      www.facebook.com/marclorenzvisualization
        Thanks a lot Vlado! yes i have never done disk defragmentation I am happy to see there is nothing wrong with my hardware.. replacing machine so quick is not in my budget. Will start formatting now! 3dsmax should come for mac soon.. i have never faced any OS related issue on my macbook. Also are you suggesting i should switch to windows 7?
        Marc Lorenz@ What is SSD?
        Prateek Vishwa
        sigpic
          This is not my experience sadly Our Mac mini, which did some of the nightly builds for Mac OS X for V-Ray for Maya, also got progressively worse with time. It may have been disk fragmentation though - I've never actually run a defragmenter on it.
            WOW! may be my poor macbook giving me full support bcoz m using it only for my presentations to clients.. all hard work is done by my PC boy one last thing, is there any advantage of switching to windows 7 over xp in regards of vray performance? Thanks once again Vlado! Ciao
            Prateek Vishwa
            sigpic
              With regards to actual rendering performance, there is negligible difference. However Windows 7 tends to look somewhat more responsive and smooth than XP in general.
                no bid deal. just reimage the machine. I tend to create image of a new machine once all the apps installed on it. I think the reason windows gets slow (personal opinion) is all the registry it accumulates over the years. Also windows 7 is more hungry for ram then windows xp, so keep that in mind. Your 4GB might not do you much good if you are working on large scenes.
                Dmitry Vinnik
                Silhouette Images Inc.
                ShowReel:
                  Ahh i see, thanks for the tip, i may not upgrade to windows7 but m thinking of adding more RAM
                  Prateek Vishwa
                  sigpic
