Modeling technique question in 3ds max
  • Modeling technique question in 3ds max
    We use splines and add extrude or editabe poly on top of it to generate roads and site in architectural visualization.
    Attached image is a site plan top view. Sidewalk, curb, roads.. etc. All objects vertexs are following the other and looks like it has turbosmoth on it. It is very clean modeling.
    All objects are seperate like roads, grass, curbs..
    How to model a site like this ?
    Thanks for your help.
    --Muzzy--
    try using your ShapeMerge tool. After you use ShapeMerge, go to Edit Mesh -> Polygon
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
      Shape merge wont give you geometry like that.
      in short, start with a plane, grab an edge, hold shift & drag it out. Keep doing that a lot. keep a meshsmooth on it, turn it on & off a lot.
      The joan of arc tutorial (head in particular) is the best terrain modeling tutorial you'll read.
      http://www.3dtotal.com/ffa/tutorials...farc/head1.php
      It'll seem really slow & inefficient at first, but you'll get faster at it in no time. for doing terrain with height changes it's amazing.
      for kerbs & raised bits, do it all flat but with edges that follow where you need them to go, then detach all the road part and lower them slightly. keeps everything inline, but one step back on your edit poly it's all one seamless piece for editing.
      keep the stack - add a new edit poly for any major changes. the best thing about working like this is being able to step back and make adjustments incredibly quickly.
        I'll do it with surface modelling, it's an underrated technique IMHO, we use it a lot when doing roads and landscape that are not flat.
          i usually drag edges on editable poly and fit it to contours
            I convert the shapes to a poly, pick the border, and us the spline to sweep a profile.
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              This is a REALLY weird topology, it seems like it was poly modeled and then smoothed but at some places i really dont know whats going on, and im not too sure how they got sharp corners. I mean, i know the methods, but without seeing a detail, i cant tell what goes on here. Whatever it is, i'm not sure if it's the best way to model this...
              Where did you get this image, and what is it?
              Dusan Bosnjak
              http://www.dusanbosnjak.com/
                Thanks for your replies.
                We got this model for a projects animation. it is definetly something like face modeling technique. or very clean spline / surface modeling or poly modeling. but every line is following eachother even on building. Very clean and smart modeling. this technique is also on Christopher Nicholas road image -attached- on vray exterior DVD and some evermotion exterior models. Want to learn how to model like this
                --Muzzy--
                  Well, surface modeling then, the mesh topology on your first image definitely could have been generated by a surface modifier.
                  It gives you a very clean start from where you can do polymodeling.
                    The second image, chris nichols road, is just about simple lofts, sweeps bevel profiles etc. Nothing fancy there.
                    Withuot seeing the first model, i wouldn't be bold to call it very efficient or smart. Looks really weird to me, and i can see a lot of weird shading artifacts happening there. Although, the same goes for modeling the terrain the traditional way.
                    Dusan Bosnjak
                      l'll post something in a bit.
                      Dusan Bosnjak
                        No offense, but i wouldnt call this super intelligent modeling. IMHO it's more bruteforce than anything. This is what goes on here, basic poly modeling. I believe that the green dots around the 90deg corner are just scaled into one point (they are still there) so when it gets smoothed they spread out but leave the sharp corner.
                        Dusan Bosnjak
                          Needs more clarification?
                          Dusan Bosnjak
                            wow... thanks
                            Dusan Bosnjak
