Good workflow for sending content to Final Cut Pro?
  • Good workflow for sending content to Final Cut Pro?
    What's the recommended workflow when sending rendered content from a PC to Apple FCP for editing / color grading? Our editor prefers we not send frames because of the high data rate (ie slow transfers) but there doesn't seem to be a good intermediate codec that'll maintain high quality from PC to Mac.
    Could use the good ol Quicktime Animation codec but that's so old I'd assume there is a better way now...
    Any suggestions?
    Christopher Grant
    Director of Visualization, HMC Architects
    Portfolio, ChristopherGrant.com
    ive gone from max to smoke and AE. but never fcp or premiere. smoke naturally can handle anything i throw at it
      I also only send out frames for use with aftereffects. PNG with alpha off unless they need the alpha instead of background.
      The problem with sending a compressed format is that after editing it they will be compressing the same footage a second time.
      Are you sending the files via the internet or are you referring to data transfer to HDD or editors internal transfer rate?
      I generally use mp4- divx, or ffd and the internal codec h.264 for stuff i'm sending via web (but people need the codecs installed to view them- otherwise flv or embedded flash ) I never do that for editing though - either raw frames or uncompressed.
      The h.264 seems to be used quite a lot in digital video cameras.
      Not sure what the 'best' codec is for editing/recompressing? Also depends on what the editor has access to.
      Here is an article on quicktime codecs if you're going that route http://www.dvxuser.com/V6/showthread...ects-(windows)
      One of the posts on this link says that it's better to keep the same codec if you're going to recompress http://www.photography-forums.com/re...ng-t38452.html so maybe see what format/codec your editor will be exporting to.
      bit off topic- but this camera looks pretty cool http://www.ikonoskop.com/dii/ shoots uncompressed HD video.
        I often use quicktime FotoJPG with 95% quality when sending out footage for editing.
        That codec is used by some stock footage studios like Artbeats.
        Reflect, repent and reboot.
        Order shall return.
