network card advice
  • network card advice
    I seem to be having problems when rendering large scenes with lots of textures etc...Im not sure if its because of the quality of my network cards so I thought I would ask what people recommend.
    I currently have a bunch of D-Link DGE-528T Adapters. These were fairly cheap...about £10 each. Do you think more expensive cards are more reliable and worth the money ?
    Regards
    Steve
    My Portfolio
    Are you pulling files/textures/proxies off a server?
    Chris Jackson
    Shiftmedia
    www.shiftmedia.sydney
      My main workstation has all my textures and proxies/assets on it and so the render nodes all pull these assets from this system.
      I did read another forum that discussed external network raid drives....Im thinking this may be the way to go..what do you think ? Maybe this would sort out the issues I have.
      Regards
      Steve
      My Portfolio
        Yeah that would be a big slow down on large scenes.
        We used to have a 4TB server here and we couldnt render large scenes on more than 4 machines as the server couldnt handle it! but now we have a 22TB server that has 4 gigabit network connections out of it and there are no bottleneck or other render issues now!
        Chris Jackson
        Shiftmedia
          I didnt even know you could get 4 gig networks. Would you recommend a particular manufacturer for the server and cards ?
          Regards
          Steve
          My Portfolio
            Actually, after looking around that may be overkill in terms of cost for my business. Would probably need to go with possibly a 2gig solution...
            Regards
            Steve
            My Portfolio
              well its not actually a 4 gig network card.
              It is 2 cards with 2 1gb connections.
              It mainly allows for a larger number of connections to be made at once without causing a slowdow.
              As for the server itself it was made by a local computer supplier.
              Chris Jackson
              Shiftmedia
                maybe he meant he had 4 seperate gigabit connections....
                  Correct!
                  You can get some NAS storage solutions that have 2 gigabit network connections on board
                  Chris Jackson
                  Shiftmedia
                    ok, that makes sense. I guess I'll have to shop around for some double connection cards.
                    Thanks for the info by the way.
                    Regards
                    Steve
                    My Portfolio
                      Check this out Steve-
                      http://www.ebuyer.com/189994-buffalo...-wx4-0tl-r1-eu
                      It doesnt have a dual network card but it will be a massive improvement on using your workstation as a server!
                      Chris Jackson
                      Shiftmedia
                        Thanks...That looks like a pretty good server.
                        Regards
                        Steve
                        My Portfolio
