Tape helper script
  • Tape helper script
    HI
    I'm trying to make the written text in a text shape object display the value from a tape helper object, ie the distance value from the tape helper?
    I cant seem to link the two parameters and haven't found a solution on the internet yet. Does anyone have any ideas?
    Many thanks,
    Mark
    It's not very difficult to link a tape's length to a text object's text.
    If you run this in an empty scene it should create a linked tape and text object.
    Code:
    	theTape = tape pos:[0,0,0] target:(targetObject pos:[0,100,0])
    	theText = text size:10 pos:[25,0,0]
    	theText.text = (distance theTape theTape.target) as string
    	when transform theTape changes id:#tape2text handleAt:#redrawViews do
    Type this into the MAXScript listener to break the link
    deleteAllChangeHandlers id:#tape2text
    How exactly did you want it to work?
    Dan Brew
      Cool solution Dan! I gave it a stab & had the same principle but I've never been able to get my head around callbacks, they make my brain hurt
      MDI Digital
      moonjam
        Thanks, too many callbacks can slow your scene down as well but in this case I think it's the only solution.
        Dan Brew
          Thanks Dan, only simple if you know how!!
          Works a treat, just the job.
          On a slightly connected note! I wouldn't mind a similar thing but having a text object display the rotation of a camera/object in Z, ie 275 degrees/or just the rotation value from the Z as I cant work out how to get max to display rotations in degrees.
          Many thanks,
            Try the DegToRad and RadToDeg functions - max works in radians internally.
              Here's an edited version for camera rotation.
              Code:
              	theCam = VRayPhysicalCamera pos:[0,0,0] targeted:false
              	camr = eulerangles 90 0 0
              	rotate theCam camr
              	theText.text = ((quatToEuler2 (theCam.transform.rotationPart)).z) as string
              	when transform theCam changes id:#cam2text handleAt:#redrawViews do
              deleteAllChangeHandlers id:#cam2text
              How are you using these, are you writing your own script?
              Dan Brew
                Thanks Dan, no, they are both just for info when we're setting up cameras, distance to target, camera bearing etc for the architect mainly!
                Just tried the script, works great. Is there a way that the script could be applied to a camera already made, with any name?
                I wish I knew scripting!!
                Thanks again,
                Mark
                  Thanks Jo, I wonder if this script could be made to do the conversion of RadToDeg as part of its internal process?
                  I dont suppose max can be made to display in degrees in its spinners! Would be nice.
                    Sorry Mark i haven't got time to do this properly. I've modified the script so that if you run the script then click on a camera it adds a text object to that camera. You can then repeat this for any number of cameras now.
                    Code:
                    	fn camFil cam =
                    		superClassOf cam == camera
                    	theCam = pickObject filter:camFil
                    	theCamHand = GetHandleByAnim theCam
                    	theText = text name:(theCam.name+" Angle") size:10 pos:(theCam.pos+[25,0,0])
                    	theText.parent = theCam
                    	theTextHand = GetHandleByAnim theText
                    	theText.text = formattedPrint ((quatToEuler2 (theCam.transform.rotationPart)).z) format:"0.3g"
                    	when transform (GetAnimByHandle theCamHand) changes id:#cam2text do
                    		if IsValidNode (GetAnimByHandle theTextHand) then
                    			(GetAnimByHandle theTextHand).text = formattedPrint ((quatToEuler2 ((GetAnimByHandle theCamHand).transform.rotationPart)).z) format:"0.3g"
                    			rotate (GetAnimByHandle theTextHand) (inverse (GetAnimByHandle theTextHand).rotation)
                    This really isn't a very good solution though.
                    Dan Brew
                      I wrote one as well that I love. It's quick and not fancy at all, because I wrote it on set for a shoot and didn't have much time. Just click the script, and then draw a line (just like a normal) spline. It will put the measurements in between each segment of the line. No callbacks, no frills. Redraw your line if you mess up.
                      Enjoy,
                      Colin
                      Code:
                      macroScript measureHelper category:"ColinScripts" tooltip:"Measure Helper" Icon:#("Helpers",5) (
                          global theDist, groupNode, getRotateAngles
                          fn setColor o = o.wirecolor = green
                          fn getRotateAngles = (
                              -- Orient the text correctly
                              case viewport.getType() of (
                                  #view_bottom: (eulerAngles 180 0 0)
                                  #view_right: (eulerAngles 90 0 90)
                                  #view_left: (eulerAngles 90 0 -90)
                                  #view_front: (eulerAngles 90 0 0)
                                  #view_back: (eulerAngles 90 0 180)
                                  default: (eulerAngles 0 0 0)
                          tool placeText prompt:"Select Placement for Text" numPoints:1 (
                              local b
                              on mousePoint clickno do (
                                  if clickno == 1 then b = text pos:worldPoint text:(theDist as string) size:5 else #stop
                                  b.wirecolor = green
                                  rotate b getRotateAngles()
                                  attachNodesToGroup b groupNode
                          local measureLine = startObjectCreation line returnNewNodes:true newNodeCallback:setColor
                          measureLine = measureLine[1]
                          if measureLine != undefined and (numKnots measureLine) >= 2 then (
                              -- Measure the distance between knots
                              local pt, prevpt
                              groupNode = group measureLine name:(uniqueName "Measure Group")
                              1
                              for k = 1 to (numKnots measureLine) do (
                                  pt = (getKnotPoint measureLine 1 k)
                                  -- Create Dummies at the knots
                                  d = dummy pos:pt name:(measureLine.name+"_knot_"+k as string) scale:[.2,.2,.2]
                                  attachNodesToGroup d groupNode
                                  if k > 1 then (
                                      theDist = distance prevpt pt
                                      local midpt = point3 ((prevpt.x + pt.x)/2) ((prevpt.y + pt.y)/2) ((prevpt.z + pt.z)/2)
                                      local distanceText = text pos:midpt text:(theDist as string) size:5
                                      distanceText.wirecolor = green
                                      rotate distanceText (getRotateAngles())
                                      attachNodesToGroup distanceText groupNode
                                      --messageBox ("Click for Text Placement: " + (k-1) as string + " of " + (((numKnots measureLine)-1) as string))
                                      --starttool placeText
                                      --format "distance between % and %: %\n" prevpt pt (distance prevpt pt)
                                  prevpt = pt
                          ) else
                              messageBox "Problem with created Measuring Spline, undefined or less than 2 knots."
                      Colin Senner
                        Hey thanks for posting this Colin! Just been trying it and works really well. I will have to make the text larger as we work in mm but I can definitely see myself using it. Surprising that there isn't something like this in Max already really.
                        @m_hinks Did the last script do want you wanted it to?
                        Dan
                        Dan Brew
                          It saves me tons of time when I have to do print screens of measurements (which isn't often), but man it's amazing for that.
                          Colin Senner
                            Hi Colin, yes its very useful, I can see that coming in handy.
                            Dan, thanks again. It is perfect for the job, except for one thing which I just found out! I have made a template file with a couple of these tapes so I can merge into files where I need it. But the script seems to be getting lost when I merge to a new scene? I'm not sure if there is any way to add the script to the new scene, or whether the method of linking the text to the length can be done on the object?
                            Thanks again, its very useful!
                            Mark
                            • #15
                              No, the when construct that I used won't survive merging into a different scene or even saving and reopening the scene.
                              Here's a different way of linking the text tape which should at least survive the scene being saved and reloaded. Not tested merging though.
                              Code:
                              	theText = text size:10 pos:[25,0,0] wirecolor:yellow
                              	textCtrl = float_script()
                              	textCtrl.addNode "theText" theText
                              	textCtrl.addNode "theTape" theTape
                              	textCtrl.addNode "theTarg" theTape.target
                              	textCtrl.SetExpression "theText.text = (distance theTape theTarg) as string\n theText.pos = theTape.center\n0"
                              	theText.kerning.controller = textCtrl
                              Just tested merging and it does work.
                              Dan Brew
