Animated V-Ray Proxy
  • Animated V-Ray Proxy
    Is there a way to basically do what Supermesher and XMesh are doing but the end product be a vray proxy object? Lets say there is a sequence of obj files that i would like to get into a single vray proxy file....is this possible.
    Dwayne D. Ellis
    ________________________
    McCarthy Engineering Inc.
    Windsor, Ontario, Canada
    Of course; you can use the ply2vrmesh tool to collect a bunch of .obj files into a single animated proxy file.
      Hmmm....must be doing something wrong here. My command line must be wrong. My directory is c:\obj\ and i'm using this:
      ply2vrmesh c:\obj\water*.* c:\obj\water.vrmesh -append
      Its creating a file in that directory with 0kb in file size while throwing up an error message saying that incementalsave_begin<> failed.
      I appologize if this is an easy one!
      Dwayne D. Ellis
        Oh and the vertex count is changing over time as well...not sure if that makes a difference or not.
        Dwayne D. Ellis
          Sorry...figured it out. Extremely useful by the way.
          Dwayne D. Ellis
            Just for the record: changing polygon counts are not an issue.
              wouldnt that mess up motion blur?
                In many cases, no.
                  Is the command line that i wrote above correct?
                  I can't remember what i did to fix it. It creates the vrmesh with the first obj then stops and throws up the error. Any help would be greatly appreciated!
                  Dwayne D. Ellis
                    I think you need to specify the extension of the input files, f.e. c:\obj\water*.obj - otherwise, ply2vrmesh will pick up all files, including the newly created output file.
                      Thanks Vlado...that was it. I'm still getting errors though:
                      Reading .obj file... 13.5 Error writing file: [VUtils::ObjInterface::init] Error in vertex definition at line 31185
                      Not entirely sure this is ply2vrmesh fault....doesn't seem like it. The obj files are being written out of Blender so there may be an issue there. I tested it twice and it seems to error out on the same obj file. I tried removing the offending obj from the sequence and it continued on and completed the sequence so i'm going to assume its on the Blender end of things!
                      Dwayne D. Ellis
                        It might be helpful to get me the problem *.obj file to vlado@chaosgroup.com so that we can take a look.
                          Sent you three obj files from the sequence.
                          Dwayne D. Ellis
