Sneal Peak: Autodesk updates Nitrous again
  • Sneal Peak: Autodesk updates Nitrous again
    http://www.cgchannel.com/2012/03/sne...rous-viewport/
    Kind Regards,
    Morne
    I wonder if it will work with VRay
    Kind Regards,
    Morne
      It works with V-Ray materials and lights to the extent that Nitrous can display them, if this is what you mean.
        All I wonder is that if it will bring new lags and bugs or not.
        for my blog and tutorials:
        www.alfasmyrna.com
          I don't care about viewport perf no more... I don't want UI LAGS !!!
          Luke Szeflinski
          :: www.lukx.com cgi
            I want vray cam to also show DOF in viewport, like in that example. And be as quick and show correct and clean soft shadows etc from VRAY Lights and Sun etc etc.
            Kind Regards,
            Morne
              Agreed. The lag is way more of an issue. Viewporting lighting is too rough at best anyway- I always find it more deceptive than helpful unless working with max lights, cameras, and materials - which I almost never do.
              Brett Simms
              www.heavyartillery.com
              e: brett@heavyartillery.com
                Its bit longer around but I find out that by ussing shell material and creating max standard materials for viewport and using vray for rendering works pretty well...
                  I prefer to just rely on RT. It works pretty well most of the time, although I'll be much happier when RT supports more of the basic functionality of Vray.
                  Brett Simms
                    This is my point! Why can't we just use VRay for this?!?!
                    Kind Regards,
                    Morne
                      I think its because there is a mental ray rep inside autodesk that code all those viewport things for MR, and there is no1 from Vray that would do it ?
                      I dunno tbh, need chaos group answer on this 1 =D
                        We do have a dedicated guy working on Nitrous support for the V-Ray materials, lights and textures, and we have done pretty much everything that is possible from our end. However some Nitrous functionality is hard-coded (like support for exposure control plugins, dof etc) and there is nothing we can do about it.
                          What about a philosophy of "shell material" or "shading group " in maya? Let us use vray settings but secretly tell max to use mental ray for display that would just match vray settings?
                            I'll pass thanks
                            If it's not accurate /the actual thing then it's likely more trouble than it's worth. Workaround like that have their uses at times, but if it's not the actual thing then the room for error is too big. I'd rather just see Chaos use those resources to get RT tuned up to fully match Vray, and then rely on that.
                            Brett Simms
                            • #15
                              keep in mind, very low-poly models, too.
                              Bobby Parker
                              www.bobby-parker.com
                              e-mail: info@bobby-parker.com
                              phone: 2188206812
                              My current hardware setup:
                              • Ryzen 9 5900x CPU
                              • 128gb Vengeance RGB Pro RAM
                              • NVIDIA GeForce RTX 4090 X2
                              • ​Windows 11 Pro
