urgent particle flow help
  • urgent particle flow help
    Hi there. I've already posted on the Orbaz forum but need some help for the final part of a project.
    I have some particles streaming left and right of the camera as the camera is moving forward. The particles stream from 6 mesh faces....they need to go up in the air and then land on a flat plan (split into 50 faces) with one particle per face...all with the same orientation. I've done everything up until the land onto the plane but cannot for the lift of me do this. Im assuming some kind of script operator within the find target module would solve this but do not even know where to start.
    Any help appreciated. I do not have box#3 so scripting is probably the only solution here.
    Regards
    Steve
    My Portfolio
    Create the sim backwards
      U make no sense...
        If I'm backwards I can't see my screen !
        Regards
        Steve
        My Portfolio
          If you start with the 50 face object you can have one particle for face emission. Attach the 6 other objects and apply find target. Reverse your footage and stir.
