What free backup sync software do you recommend?
  • What free backup sync software do you recommend?
    Hi all
    So I have 2 external drives and also 2 seperate pc's all with more or less the same information that I copy to each other manually. I have this because sometimes I use 1 drive off-site and sometimes some else is using my pc and also I need backup etc. The problem is the "MORE OR LESS same information". I'm finding I'm forever copying information between devices and it's becoming a bit of a mess to keep track of things and to keep all the devices updated.
    Ideally if something changes, I want those changes only to be synced to the other drives etc. So if for example I add 3 photos to my main drive, I want to plug in my external backup drive and it will automatically copy only those 3 photos to the external drive. Then I want to take that external drive and connect it to for example my laptop which in turn will then also get those 3 photos.
    Would be nice if for example I can also setup a FULL backup sync as 1 job (for a specific external drive), but only a selected couple of folders as another job for a different external drive
    Because I would like a full backup on 1 drive, and say for example only photos and family stuff on another drive.
    I have 3 external seagate drives. Isn't it suppose to come WITH software that do what I need?
    If not, then what FREE backup sync software can I use for this?
    Kind Regards,
    Morne
    I use synkron: http://synkron.sourceforge.net/
    super reliable, I've used it for years. Many options for how to back up.
      Yes I'm also looking at these:
      http://synchronicity.sourceforge.net/
      http://winmerge.org/
      http://freefilesync.sourceforge.net/
      Anybody else had any experience with any of these or the one andybot_cg mentioned?
      Kind Regards,
      Morne
        Then there is this Free tool from Microsoft: SyncToy, it is part of Microsoft PowerToys
        http://www.microsoft.com/download/en....aspx?id=15155
        what you think?
        Kind Regards,
        Morne
          crashplan is what i use.
          Reflect, repent and reboot.
          Order shall return.
            what you think?
            I use this for my daily off-site backup of all my wip, works fine for me; at the end of the day I plug in my usb key and run the sw and it searches into the paths you selected if something has changed then it goes on with the synch process
            Alessandro
              what you think?
              I tried it early on, and it lacks a lot of features compared to Synkron, so gave up on it.
                I've used Syncback Pro for years and wouldn't use anything else. There is a free version - http://www.2brightsparks.com/
                  i use it everyday to sync my workstations (work+home)
                  works perfect
                  that way i have 3 copies of my files...safe enough
                    I've been using Allway Sync for several years now. After reading through these posts it seems very similar to FreeFilesync.
                    http://allwaysync.com/
                      I use Synctoy mostly for this kind of thing, but have also used RichCopy for synching between network drives. SyncToy needs mapped drives - doesn't seem to work with network paths- otherwise it covers me just fine. For a long time I just used a simple .bat file to accomplish this too. What you are after sounds pretty simple - I'm sure any of these options would be fine.
                      b
                      Brett Simms
                      www.heavyartillery.com
                      e: brett@heavyartillery.com
                        Sykron looks good, i just started my first multisync.
                        I guess that feature is what you should use for backups?
                        Order shall return.
                          @ tammo - since I have multiple folders I am synchronizing (instead of a whole drive), I actually set up individual tabs and use scheduler. I don't like multisync because from what I recall, it tries to recreate the directory structure on the destination drive. I forget now exactly how multisync works, I just ruled it out early on as I was trying out different settings. I just want to have absolute control over which folders get written to and how (there are a couple different ways of setting up the master-slave relationships.) The tabs work great for that. It's also a very transparent program and you can see exactly what it's doing (plus you can preview what you are syncing, easily set up blacklists, and it makes a copy of anything that is overwritten so you can restore very easily.)
