dvd question
  • dvd question
    ok. so ive got to do some DVDs for a few of the islands in the caribbean. Im going to set it to region 0 so that all will work. i initially did it as NTSC 24p. is the only difference between 24p NTSC and 24p PAL the frame size? and i think some of the countries use SECAM ewww. not even sure what to do with that
    yes frame size AND frame rate
    NTCS is 29.97 or 30 frames/second 720X480 I think (dont usually work on NTCS so dont know size)
    PAL is 25 frame/second and 720X576
    and depending on the tv it also wont show the full frame, the edges gets cut of a bit
    there are also some MINOR difference in colour apparently, but I never worry about that
    Kind Regards,
    Morne
      im using 24p though. so its 720x480 24p and 720X576 24p
