Urgent maxscript help needed
  • Urgent maxscript help needed
    Hi all
    So I have a LOT of objects in the scene. I will select a bunch of them (couple of 10's of thousands) and then I need a maxscript command to assign a "Map Scaler OSM" to each of the objects seperately, and set the scale of the mapscaler to 1000mm
    Please help
    Kind Regards,
    Morne
    This should create a unique modifer to each selected object.
    for i in selection do
    MyModifier = MapScalerOSM ()
    MyModifier.scale = 1000
    addModifier i MyModifier
      thanks
      if a particular object already has a mapscaler, how can I exclude that object from getting another one?
      Kind Regards,
      Morne
        Is the previous mapscaler modifier always on the top of the stack or just somewhere in there?
          somewhere in there
          Kind Regards,
          Morne
            That's a bit trickier... I'll try to do it later if no one else responds.
              thanks, if all else fails I'll just use yours as is. As far as I understand it will use the topmost one last, so that's fine, except in the odd occasion where I have the previous one set to channel2
              Kind Regards,
              Morne
                Building on Berglte's script:
                This will check for a previous MapScalerOSM mod and make sure it doesn't get applied twice:
                Code:
                	local modFound
                	objs = getCurrentSelection()
                	for o in objs do (
                		-- Reset the modFound variable each object
                		modFound = false
                		-- Check all modifiers for a MapScalerOSM
                		for i = 1 to o.modifiers.count where (classof o.modifiers[i]) == MapScalerOSM do
                			modFound = true
                		-- The mod isn't on this particular object
                		if not(modFound) then (
                			if validModifier o MapScalerOSM then (
                				myModifier = MapScalerOSM()
                				myModifier.scale = 1000
                				addModifier o myModifier
                Do you need the code to set all mapScalerOSM's to 1000 or you good?
                Colin Senner
                  Nice!
                  I also managed to get it working after searching for a while. Bobos examples helped once again
                  for i in selection where
                  (for m in i.modifiers where classOf m == MapScalerOSM collect m).count == 0 do
                  MyModifier = (MapScalerOSM())
                  MyModifier.Scale = 1000
                    You'll want a check in the berglte to make sure the modifier is valid before you add it (validModifier) otherwise the script will fail on camera/light selections. . I expanded mine for clarity too so it can be retrofitted by someone else with a similar issue. Cheers.
                    Colin Senner
                      Alright, thanks for pointing that out!
