deform array according to map
  • deform array according to map
    Hello,
    i need some help
    i have an array of small coins. i need to change the Y-rotation value of each coin according to a grey scale image value (let's say black = 0 degrees, and white = 90 degres)
    how do i do this ?
    thanks
    There a different ways. Scripting would be one, or using PFlow.
    Regards,
    Thorsten
      Like this?
      10 chars
      Dan Brew
        The are links to the script here
        Dan Brew
          Thanks will look into this!
            You can do this with Multiscatter using a color image where the RGB values transform the XYZ rotation.
            About 6:20 into this video is show this in action - http://youtu.be/2Cq3i1wMAO0
            And with Itoo's Forest Pack as well - http://www.itoosoft.com/forestpack/r...ftransform.php
