Guys do you know maybe somekind of plugin, script that will create animation of object building up from pieces. Let's say I have some logo build of Lego blocks and I want those pieces to be just lying on the table and then start building up the structure.
tips for creating animation of Lego blocks building up ...
Tags: None
Ok I demolished it with massFX but the problem is it's blowing up right form the start, instead of just fall apart.Luke Szeflinski
:: www.lukx.com cgi
You should be able to do this pretty simply with Particle Flow even without any of the boxes. You'd need to store the positions of the blocks (assembled and disassembled), then use a collision test to swap between the two. You could even use a rigid body sim (Reactor/MassFx) to scatter the blocks (I say could, because I haven't actually tried this)
I'm currently waiting on a load of renders so can't mock up a test or give you anything clearer than that, but will take a look when I get a free moment and see if I get get it working.
