I'm working on a large model of a building site, and I have received the Revit files from the architects. Originally I used the "suite workflow" they included and sent the file directly to max 2013 from Revit. Problem was then that regardless of what options I selected, it always grouped objects by materials or type, even when choosing none.
After that I decided to do a manual FBX export. My new problem, other than a weird system of not all instances being instances, I had a relatively simple scene clocking in at 168 megs, but even more worrying, that it took 7 minutes to save (locally on my system SSD). It turns out that every object has a unique material, with a unique map, resulting in several thousands of materials and maps all illogically connected to various multisub materials, per object. (Like 930 materials for the 930 identical steel parts of a handrail).
I have tried the classic replace by assigning a material with an identical name and getting it to ask me if I should rename or replace, but not all names are the same, so this doesn't help much. Also AD materials update considerably slower than other materials in the SME using vray it seems.
Does anyone have any tips on how to handle this?
