I save a Maya 5 FBX open it in Max 6 Looks Great!
  • I save a Maya 5 FBX open it in Max 6 Looks Great!
    I save it open it …and I loose the smooth info and it gets all fasted….
    If I collapse it to a mesh same thing
    Not sure where to look for the answers on that…
    The odd thing is that it looks perfect in max …until I save and re open it
    did you check to see if the vertices are welded?
    LunarStudio Architectural Renderings
    HDRSource HDR & sIBL Libraries
    Lunarlog - LunarStudio and HDRSource Blog
      Maybe you can add a smooth modifier, tick autosmooth and see if this helps.......................
      Alex
        The problem is known. Maya smooth edges, while Max does have smoothing groups by Polygones.
        Nobody has yet written a translation programm. It wouldn't be to hard to do, but...
        Well, there is no way to translate smoothing between Maya and Max yet.
        robert
        I'm registed believe me! Just miss that logo.
          hmm yeah the odd thing is that it does look good ...when it imports..
          so Im tryine welding the main file....
          but
          i think I got to go and smooth ..each one...as it stands
            Have you tried export a camera between the max to maya? I'm trying to do that now and everything works great but I can't seem to get the camera right. The camera always comes into maya turned to the left 90 degrees. Aside from that it's perfect.
            Any idea's suggestions on how to fix that???????
            www.rayduststudios.com
              Maya's coordinate system is Y-up by default. Max is Z-up. You can switch Maya over to Z-up, however Max can't be changed as far as I know. Check your prefs -- it's in there, but I haven't used Maya in almost two years so I can't remember where exactly.
              Shaun
              ShaunDon
                When I change Maya to be Z-up I get the same results
