Zbrush Goz import changes to mental ray renderer
  • Zbrush Goz import changes to mental ray renderer
    Is there a way to keep zbrush from changing the render engine to mental ray when using the Goz export directly to MAX 12?
    Just purchased zbrush so any help wpuld be greeat.
    Please customize Macro_GoZ.ms with reference to the following threads.
    Then, GoZ will not change a renderer.
    http://www.zbrushcentral.com/showthread.php?126654
    OakCorp Japan - Yuji Yamauchi
    oakcorp.net
    v-ray.jp
      They've actually changed the Macro_GoZ.ms script since those fixes. I've tried editing the current script myself with what I thought would work but every time it seems to cripple GoZ Will see if I can have another prod at lunch.
      MDI Digital
      moonjam
        Thanks for the replies. It seems they would take different render engines like vray into account since it is such a popular program.
        AJ if you find a solution, myself and many others would appreciate a heads up. Thanks.
