FloorGenerator bug
  • FloorGenerator bug
    ¿Does anyone knows how to by pass this bug?,
    1. Create a spline (acroos all borders from a room)
    2. Create geometry with Floorgenerator.
    3. Results on a geometry (diferent to original spline shape) locate on origin (not on top of spline like the usual behavor).
    Im keep getting this results no matter what, fe. create in a new fresh file to isolate the problem.
    Arch Pedro A. Solano
    "Save the irradiance map, save the render"
    Vray 3.10.03|3DMax 2011 x64|Intel Core i7-2600 CPU @3.4GHz|16GB Ram|Windows 7 Ultimate SP1
    Follow us on facebook
    Visit us on PSolano
    No one have reported similar issues, so unfortunately I have no idea what is going on.
    /Thomas
    www.suurland.com
    www.cg-source.com
    www.hdri-locations.com
      Hi Thomas, thanks for reply
      I uploaded the max file for you to look whats going on. When i run the script and generate the geometry i get this message on maxscript window
      Code:
        Start : Creating Floor
            Start : Initialize
            Stop  : Initialize : 0.047 seconds
            Start : Create pattern
            Stop  : Create pattern : 0.003 seconds
            Start : Boolean
            Stop  : Boolean : 0.027 seconds
            Start : Weld, Extrude, Bevel
            Stop  : Weld, Extrude, Bevel : 0.032 seconds
            Start : UVW, Tilt, Rotate
      Warning! Error occured while creating the floor!
      Thanks
      Visit us on PSolano
