Can't Move Objects
  • Can't Move Objects
    I have this library of cabinet door. It's one max file, with a dozen doors, and I deleted all but the one I need. All is good, but I can't move them. The later isn't locked, and I get the UCS arrows. What's up? I have tried everything!
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Try to unlink it. In case it´s linked and the inherit translate parameters are unticked.
    (wich doesn´t make sense at all but it´s worth a try )
    Look at the motion controls, maybe something else than "Position XYZ" was set for this objects.
    And if absolutely everything fails, use a mesher object.
      Ugh! here's the file, if you would like to take a peak.
      http://www.sendspace.com/pro/dl/i89gwu
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        got the bugger! Link Info Locks!!!
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
