Why would you use it? Unless you were doing a cut-thru, is it useful for anything else?
Camera Clipping
Camera Clipping
Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- Windows 11 Pro
Tags: None
sometimes you need a very wide angle to fit into a room to see everything. The wide angle may distort too much. Then just stick the camera behind a wall and use normal lens and camera clipping to "bypass" the wall or whatever else is in the wayKind Regards,
Morne
Originally posted by Morne View Postsometimes you need a very wide angle to fit into a room to see everything. The wide angle may distort too much. Then just stick the camera behind a wall and use normal lens and camera clipping to "bypass" the wall or whatever else is in the wayBobby Parker
phone: 2188206812
- Windows 11 Pro
Originally posted by Morne View PostIt works well for small spaces like bathroom scenes or small receptions. Just wish there was a way that we could angle or rotate the clipping plane.Alain Blanchette
www.pixistudio.com
