Hi Vlado,
Just as a quick one, I've found a method to take the fresnel equation for metals and loop through 0 to 90 degrees working out the reflection part using the real and imaginary values from refractiveindex.info but of course with metals not being 100% reflective, there's also a diffuse component. Do you know of any method or scale or system to work out what the diffuse colour would be to go along with them? And also assuming the info I have is correct as regards the percentage of reflection at each angle, I'd only really need the hue of the colour to be accurate with the energy preservation laws removing the majority of the diffuse contribution once the reflection is applied?
Cheers!
John
Cheers!
John
