whos got i7-3930K and is OC'ing?
  • whos got i7-3930K and is OC'ing?
    So who is using OC'ed stable i7-3930K for working?
    I have ASUS P9X79 WS and Noctua NH D14 fo cooling.
    So far I got: 4.5Ghz with 1.375 V : idle temp: 40, Full Load : 80
    Luke Szeflinski
    :: www.lukx.com cgi
    i have a rampage gene (mini atx) with corsair h80 and 32gb.. 4.5ghz at 1.32v idle 37 degrees load 65 (in winter) 70-80 in summer (i live in southern italy..)
      I've an ASUS P9X79 and a thermalright macho 02 - Lukx what settings did you use to achieve your OC?
        I setup everything like guy from ASUS: https://www.youtube.com/watch?featur...&v=Kx2z07sFM2I exept his Ghz and Vcore.
        But after running Prime95 it was crashing and now I have 4.3 Ghz with 1.295 Vcore
        Luke Szeflinski
        :: www.lukx.com cgi
          Much appreciated! I did a bios update and for some reason now no matter how early or often I hit del I can't get into my bios - must do another bios flash and see can I start fiddling
            keep me posted
            Luke Szeflinski
            :: www.lukx.com cgi
              I did my 3930k on my Rampage IV x79 board super easily to 4.2 on water. I didn't really push it higher to be honest, but I'm sure I could go higher if needed.
              Colin Senner
                Colin what voltage ? what water cooling you have? Corsair H80 , 100 ?
                Luke Szeflinski
                :: www.lukx.com cgi
                  Corsair H100. I didn't manually tweak my voltage, my bios has some easy settings for a quick OC. I'll grab the vcore and stuff for you when I get home tonight.
                  Colin Senner
                    OhI wanted to buy this Corsair H100 but I heard it's quite loud? Some high pitch sound can happen etc.
                    Luke Szeflinski
                    :: www.lukx.com cgi
                      I bought 3 i7's 2600k a few years ago and OC them to 4.5 each, one of them burned the cpu with in a month
                      Dmitry Vinnik
                      Silhouette Images Inc.
                      ShowReel:
                        That's why I never wanted to even try OC. Equipment is a lot more expensive down here in SA
                        Last time I burned a CPU was when I was still in IT and a 486AT was King. CPU's still had pins and it could go in the slot any way - and apparently overheat in a few seconds if you drop it in the wrong way hehe
                        Kind Regards,
                        Morne
                          Well I got it replaced, after that I throttled them down to 4.0 and they run fine. I used to get a lot of kernell power messages under high OC, I'm sure its some how related...
                          Dmitry Vinnik
                          ShowReel:
                            I bought it and swapped out the fans on top with some really nice ones.
                            Colin Senner
                            • #15
                              which ones did you get?
                              Kind Regards,
                              Morne
