Ozone and LWF with VRay
  • Ozone and LWF with VRay
    Anybody got this to work?
    I'm trying the version 6 PLE, and so far the gamma settings inside Ozone doesnt seem to do anything. Switched it on and off, also changed it from the default of 1.8 to 2.2 and also tried 1.0. Doesnt do anything.
    The clouds either comes out way too bright, or way too dark. Doesnt seem to match the vrayphysicalcam exposure and sun
    Also there's no tutorial. so how you suppos to learn. How people have time to "try" 100000 settings. A tut goes so much quicker to understand what you suppose to be doing...
    Kind Regards,
    Morne
    I've had the same problem in the past with Vue XStream. Which is basically a more powerful version of Ozone. It behaved as if you set the environment the way it should render in Vue then get your 3D Max scene to match that. Trying to get Vue settings to match your 3d Max/Vray settings (such as gamma 2.2 in your case) was uesless.
