Did anybody try to install the Autograss update, which was sent out last week? I am having flashbacks! It will not install on my slaves, and my e-mails are not being returned.
Autograss Update
Autograss Update
Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- Windows 11 Pro
Tags: None
why won't it install?Dmitry Vinnik
Silhouette Images Inc.
ShowReel:
Bobby Parker
phone: 2188206812
- Windows 11 Pro
But, it seems even though the slaves didn't install, it's still rendering fine with the earlier version.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Hello,
I had a problem during the installation on some of my render nodes.
The Producer answered, thad I need a update:
http://download.microsoft.com/downlo...redist_x64.EXE
Now it works fine here.
Regards
Alex
Yes. I got a response this morning with the same fix, which solved my install issue.Bobby Parker
phone: 2188206812
- Windows 11 Pro
I got the fix, too, but now if I activate DR, render is all black. no errors from slave and renders fine if I switch off DR...waiting on answer still.
On the bright side, it seems to be very much improved, but I have to give it some more exercises...
So did mine, but it was a mapping issue. I tested it using their sample file. I used Colins Relink script, which mapped the proxy (I think). Whatever it was, it solved the issue. The name was longer then the dialog, so I don't know if it was a proxy or texture map.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Originally posted by glorybound View PostSo did mine, but it was a mapping issue. I tested it using their sample file. I used Colins Relink script, which mapped the proxy (I think). Whatever it was, it solved the issue. The name was longer then the dialog, so I don't know if it was a proxy or texture map.
Hmm, well, nothing was missing, but after rendering the sample scene, DR now works in other scenes, too.
Not sure what was up, but for now it is resolved. Thanks again for the tip as I never would have tried the sample scene as a solution.
