We have a few machines that we use for rendering which are based upon an i7 sandybridge 2600k with no overclocking. One of these machines (identical to another 2) seems to be running its CPU very hot indeed. With Prime95 x64 running its torture test, the temps are between 94 and 98 degrees! This seems way too hot to me. An identical machine runs at closer to 70 degrees.
I have removed, cleaned, and re attached the 3rd party cooler (one of those Arctic Cooling Freezer 7 jobs) and applied new thermal paste, but it has made no difference. Even running idle, the CPU is around 50 degrees. The motherboard is using the latest bios.
Any suggestion why this might be happening? Its a good quality case, and the ambient room temp is 20-23 degrees. Apart from switching the CPU into one of the identical machines, I have run out of ideas.
