python - list connections, too many...
  • python - list connections, too many...
    Heya
    Bit sort of non/related question...
    I'm trying to list incoming connection to my shader but I get some extra nodes I'm not sure how to filter out
    I want to make a script to disconnect textures attached to nodes on multiple shaders. I got MR one working but Vray for some reason somehow is picky...
    Any hints?
    selected = cmds.ls(sl=1, mat=1)
    for materials in selected:
    connections = cmds.listConnections(c=1)
    newMatName = materials +'.diffuseColorAmount'
    for inNodes in connections:
    cmds.disconnectAttr(connections,newMatName)
    # Error: Invalid argument 1, '[u'VRayMtl1.message', u'materialInfo1', u'VRayMtl1.message', u'defaultShaderList1', u'VRayMtl1.outColor', u'VRayMtl1SG', u'VRayMtl1.diffuseColorAmount', u'VRayFlakesMtl1']'. Expected arguments of type ( , )
    # Traceback (most recent call last):
    # File "<maya console>", line 6, in <module>
    # TypeError: Invalid argument 1, '[u'VRayMtl1.message', u'materialInfo1', u'VRayMtl1.message', u'defaultShaderList1', u'VRayMtl1.outColor', u'VRayMtl1SG', u'VRayMtl1.diffuseColorAmount', u'VRayFlakesMtl1']'. Expected arguments of type ( , ) #
    Thanks, bye.
    Instead of
    Code:
    should it not be
    Code:
        cmds.disconnectAttr([color=red]inNodes[/color],newMatName)
      Heya Vlado
      Thanks for fast reply.
      Humh silly me that makes more sense than what I had. But atm for some reason it is still not working. The cmds.listConnections(c=1) still give me a lot more nodes that I need. I end up with error again.
      Code:
              cmds.disconnectAttr(inNodes,newMatName)
      # Error: There is no connection from 'VRayMtl2.message' to 'VRayMtl2.diffuseColorAmount' to disconnect
      # RuntimeError: There is no connection from 'VRayMtl2.message' to 'VRayMtl2.diffuseColorAmount' to disconnect #
      I know whats wrong with it I'm just not sure how to filter out the data I want
      This is my MR version of script which works last time I check...
      Code:
      	mats = cmds.ls(sl=1)
      	for mat in mats: # iterate
      	    conns = cmds.listConnections(mat, p=True) or [] # get connections
      	    cmds.editRenderLayerAdjustment('%s.%s'%(mat,'reflectivity'))
      	    cmds.editRenderLayerAdjustment('%s.%s'%(mat,'refl_color'))
      	    for conn in conns: # iterate
      	    	try: #...
      	        	cmds.disconnectAttr(conn,'%s.%s'%(mat,'reflectivity')) # disconnect
      	        except: #...
      	        	pass  #...
      	        try:
      	        	cmds.disconnectAttr(conn,'%s.%s'%(mat,'refl_color')) # disconnect
      	        except:
      	        	pass
      I know its not the prieatest one and TRY function hide a lot of issues but it does work (somehow)...
      I tried the same with vray and no luck
        What stops you from using the try/except code for the V-Ray code too??? You are probably getting errors with the MR code as well, but they are ignored because of the try/except.
          Well that's the tricky weird think. When I tried try/pass it didnt work either.It execute the scripts, connection still stays and nothing happenz. I need to retest it another 10x see if I can come up with some "Creative" way of fixing it
          Thanks for help Vlado.
