Service Pack 1 for 3ds Max 2014 and 3ds Max Design 2014 is available!
Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- Windows 11 Pro
Tags: None
Lots of fixes. Anyone tried it yet? I think I'll hold off for a week or so...
I installed it, and like usual, it took a long time. The communication error stopped popping up at launch, but other than that, I wasn't having any other issues prior to the update.Bobby Parker
phone: 2188206812
- Windows 11 Pro
There are a heapload of small UI/navigation/viewport issues with vanilla 2014. Not sure how you've managed to avoid them, Bobby...! For me on many occasions I'm forced to click the viewport before I can use a keyboard shortcut. That's a major irritation. Hope they've fixed that one.
Now, I have been having keyboard shortcut issue, but I wasn't blaming that on MAX. if that annoyance is gone, I would be happy.Originally posted by alexyork View PostThere are a heapload of small UI/navigation/viewport issues with vanilla 2014. Not sure how you've managed to avoid them, Bobby...! For me on many occasions I'm forced to click the viewport before I can use a keyboard shortcut. That's a major irritation. Hope they've fixed that one.Bobby Parker
phone: 2188206812
- Windows 11 Pro
i am on it
pretty good!!!
couple of glitches and bugs are there...viewport/UI
better that 2013....everything is better than thatMartin
http://www.pixelbox.cz
I have installed the SP, and nothing works anymore! The Autodesk forum says that 3DS MAX 2014 doesn't work on XP, because XP doesn't support Direct X 11. MAX 2014 worked fine, prior to the SP, so I am baffled. Now, the SP works fine on my Win7, but then I sent a render to DR, the slaves (all XP machines) didn't render, so I applied the SP, and that's when things got broke.
http://forums.autodesk.com/t5/Autode...highlight/trueBobby Parker
phone: 2188206812
- Windows 11 Pro
Originally posted by glorybound View PostI have installed the SP, and nothing works anymore! The Autodesk forum says that 3DS MAX 2014 doesn't work on XP, because XP doesn't support Direct X 11. MAX 2014 worked fine, prior to the SP, so I am baffled. Now, the SP works fine on my Win7, but then I sent a render to DR, the slaves (all XP machines) didn't render, so I applied the SP, and that's when things got broke.
http://usa.autodesk.com/adsk/servlet...linkID=9241177
I think Revit 2014 is the same if I'm not mistaken, doesnt even install on XPKind Regards,
Morne
I am already uninstalling the SP, but I am sure others will come across the same thing and stumble across this thread, and try it.Originally posted by Morne View PostHow about setting all your XP slaves to start up in OpenGL mode?
Maybe that's a workaround?
I don't have XP so can't test it...Bobby Parker
phone: 2188206812
- Windows 11 Pro
one day, it was the latest. I use 5 machines solely for vray dr slavesOriginally posted by PIXELBOX_SRO View Postmay anyone explain to me whats the reason to use winXP???Bobby Parker
phone: 2188206812
- Windows 11 Pro
