superspray
  • superspray
    Hi There,
    trying to make a fountain animation, but I am running into some funny thing with superspray :
    it seems as if the particles is not ejecting in a smooth flow, you can see this as it curves down bent by the gravity.
    it looks like the particles is not been created in a seamless flow.
    anybody have an idea what it could be?
    It looks more like a motionblur issue to me...
    Kind Regards,
    Morne
      Hi Morne,
      attached is without any blur.
      you can see the breaks in the particles
        Maybe try and modify this one to your needs...
        spray.zip
        I saved it down to 2012 (not sure which version you're on)
        On your example, did you use 3D mesh particle or facing planes?
        Kind Regards,
        Morne
          In the file in my previous post, you get a nice moblur if you set your f=22 and shutter=30, iso=100
          Perhaps also increase the number of particles
          Kind Regards,
          Morne
            Thanks Morne, will check it out today
              HI Morne,
              great thanks, it works great.
              Somehow our spray have a scaling issue which makes the spray spray like a sprinkler.
                Originally posted by WimOos View Post
                HI Morne,
                Hi Wim
                Glad I could help.
                Could you perhaps post your spray just for the sake of interest so I can attempt to dissect where the problem could be?
                Kind Regards,
                Morne
