Real Liquid
  • Real Liquid
    Now, this looks cool!
    http://www.wimp.com/liquidreal/
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090
    • ​Windows 11 Pro
    doesn't look that good.
    Phoenix can achieve results like that infact I think phoenix could make it look better!
    Chris Jackson
    Shiftmedia
    www.shiftmedia.sydney
      Can't beat the price
        Its pretty good, but 220+ hours to render? Good grief.
        Kind Regards,
        Richard Birket
        http://www.blinkimage.com
          It's about 24 seconds long, assuming it was 25 frames per second and assuming it was 225 hours that would be 23 minutes a frame, which isn't completely insane if they only used one machine.
          MDI Digital
          moonjam
            +1 with Chris, pretty sure that PhoenixFD can do same (or even better-->foam and splatches in addition) with ease.
            Want me to have a try, just to be sure ?
            Jérôme Prévost.
            SolidRocks, the V-Ray Wizard.
            http://solidrocks.subburb.com
              Phoenix can def. do better, and vray can render it faster too.
              It's just a good hdri - if it had reflective caustics or a more complicated lighting setup i'd understand more but I'd get shouted at if I tried to get away with that taking 20 mins a frame in 1080p.
              If it's being done on a 3 year old laptop, then sure...
                Just spotted there's a link to the original Youtube clip with extra information below the video.
                Uploaded on 10 Feb 2012
                This one took quite some time to setup and finetune. Neither Blender's internal render engine nor Yafaray produced acceptable results, so I decided to use LuxRender in unbiased MLT mode.
                Combined with a custom HDR background image lighting the scene, it delivers very realistic output at the cost of astronomic render times. One frame out of 710 took about 22 minutes to render, but without a good noise filter it would have taken at least twice as long.
                Here's the .blend file:
                https://rapidshare.com/files/30316447...
                https://dl.dropbox.com/u/23004939/Ble...
                I works with Blender 2.63 and higher, make sure you have the LuxRender addon installed and active. You will need to rebake the simulation and use a different HDRI environment though.
                PC specs:
                CPU: AMD Phenom II X6 1090T @ stock speed
                GPU: Zotac GTX 570 AMP! (was not used for rendering this)
                RAM: 8GB 1600 MHz
                SSD: Samsung 830 128GB
                HDD: 2x 640GB + 1x 500GB WD caviar blue
                MDI Digital
                moonjam
                  Well, download Houdini PLE for free
                  http://www.sidefx.com/index.php?opti...589&Itemid=221
                  take a 30min tutorial
                  http://www.sidefx.com/index.php?opti...157&Itemid=132
                  get a better result
                  http://www.cgmotionbox.com/wp-conten...-Waterfall.jpg
                  ok.. mantra is pretty slow.. but maybe just because i don´t really know it
                    Oh man that video was like time traveling to 2005 to check out Glu3d.
                    Ville Kiuru
                    www.flavors.me/vkiuru
