Processor help
  • Processor help
    Hello
    I'm looking at buying a cheap new workstation for home.
    I currently have a 5 year old dual xeon E5462 @ 2.8 GHz mac pro. looking at cpubenchmark.net each processor has an average CPU mark of 4220. I am reasonably happy with this setup
    The workstation I am looking at has an i7-4770 @ 3.40GHz average CPU mark of 9996
    The Xeon has quad core processors, so 8 bucket rendering, whilst the i7 will have only 4
    Are the 2 processors comparable in speed? ie is it a matter of 2x4220=8440 vs 9996? Meaning that the i7 single processor is faster that the dual xeon?
    Thanks
    www.EeDesign.co.uk
    Its quite hard to compare it (in the time I have to write it atm ) but basically
    I7 = 4 cores but its 8 buckers since cores have HT meaning 1 core = 2 buckers.
    Either way
    I7 power = 4x 3400mghz = 13600mghz
    Xeon power = 8x 2800mghz = 22400mghz
    So your xeon will be faster in rendering
    However it will be slower in any 1 cpu based tasks - saving, loading, 50% of photoshop etc etc
    Now given the technology advancements I could expect that I7 would perform at a speed of 14000mghz-20000mgz if it were compared using other specs than just cpu speed(ram, technology etc etc)
    So it could be either very close fight or far away. Depends on software... I cant be sure for 100%. I saw insane performance boost over recent intel cpus and not so much more mghz so I'm bit lost.
    Anyway hope that helps.
    Try getting 6 cores i7 i3990K and OC to 4.5ghz -that will eat alive that xeon you have now.
      Thanks DADAL
      Can't find a 6 core i7 workstation at the moment.
      My xeon is a mac pro with 10 gb RAM
      the new one potentially a dell xps 8700 http://www.dell.com/uk/business/p/xp...el_id=xps-8700
      www.EeDesign.co.uk
        Make sure that you have a very good case with a new cooler for the processor.... If you overclock it you could increase the speed by 50%... A gamer mother bother will help you to get maximum performance an affordable price.
        show me the money!!
          Try Scan.co.uk or PCspecialist.co.uk
          They both will build you PC to your specs and Overclock it on warranty. You will save 50% money and get 50% more power than Dell or HP. Also their warranty is very good.
            i suggest i7 3930K cpu. very good price/performance. 6 core = 12 buckets, and OC running here @4.2Ghz (with noctua NH-d14) 24/24.
            Jérôme Prévost.
            SolidRocks, the V-Ray Wizard.
            http://solidrocks.subburb.com
              I recently bought an old dell server, which is a dual quad (8 cores) without HT. @3.4 ghz. It renders about 1.5 times slower then i7 3930k. Not to mention that you can overclock the i7 and get it to probably double the speed of the xeon. I have my main workstation as a dual six core (12 total) xeon, and the i7 performs equally with just one cpu, I wish intel really allowed to seed two of those on one mobo, but that would kill the xeon
              Dmitry Vinnik
              Silhouette Images Inc.
              ShowReel:
                This might help: http://www.cpubenchmark.net/high_end_cpus.html
                - Geoff
                  And I have no idea why a Xeon E5-2665 is nearly three times the price of an i7-3930K. It's only 3% faster.
                  - Geoff
                    Im guessing it has 8 cores, which is for now quite rare for xeon cpu, also perhaps its clock speed in turbo mode. And just because its a xeon cpu
                    Dmitry Vinnik
                    ShowReel:
                      Also the sad thing about 3930k is that though it has 6 cores vs the 2600k 4 cores, its only marginally faster. I bought two of the 3930k, and for some reason I cannot overclock them, and so under the stock speed they run slightly faster then overclocked 2600. By slightly I mean 2%-5%
                      Dmitry Vinnik
                      ShowReel:
                        If you order a computer from www.cyberpowerpc.com they claim to be able to overclock a 3930k by "at least 20%" if you pay for that.
                        - Geoff
                          perhaps. I could get them to oc and run fairly stable. But they would bsod every couple of days, sometimes they would run for weeks but eventually bsod. I gave up for now...So they may overclock them, but I doubt that would qualify as stable.
                          Dmitry Vinnik
                          ShowReel:
                            What motherboard did you pair with that i7? Some motherboards CANT overclock cpus.
                            As to shops like I said b4 scan and pcspecialist will OC them to 4.5 ghz stable with no bsod...
                            • #15
                              Thanks for all the replies. I will try scan and pcspecialist and see what I can get.
                              www.EeDesign.co.uk
