invert animation keyframes
  • invert animation keyframes
    possible? ive copied a set of keyframes from one axis to another but they need to be exactly inverted, as in the motion needs to be going the other way. there must be a simple way to do this i guess..
    What type of controller are you using?
    Dan Brew
      If you just need them to swap over you can use the scale keys button in the track editor and do it to -100%, then shift them back to their original position. It uses the current time as the center point for the scale, so you could probably get the current time dead center of the animation and have it swap places fine.
      Make sure that snap frames is switched off, might cause lurching depending on how you've got it set up/if you dont get it -100.00 exactly.
        Select the animated object. Open your trackview. In the top left corner switch to editor/dope sheet.
        turn on edit keys (the checker button in the top left). Expand the controllers and select those you want to reverse.
        Choose "select time" from the menue.
        Select the desired range. than hit the "reverse time" button also from the menue.
          thanks everyone
