Anyone had this error before ? Comes up in a window but max still starts. Not sure why this is happening suddenly..
Code:
System.InvalidOperationException: There is an error in XML document (18, 4). ---> System.IO.FileNotFoundException: Could not find file 'C:\Temp\24betjah.dll'. at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath) at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy) at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share) at Microsoft.CSharp.CSharpCodeGenerator.FromFileBatch(CompilerParameters options, String[] fileNames) at Microsoft.CSharp.CSharpCodeGenerator.FromSourceBatch(CompilerParameters options, String[] sources) at Microsoft.CSharp.CSharpCodeGenerator.System.CodeDom.Compiler.ICodeCompiler.CompileAssemblyFromSourceBatch(CompilerParameters options, String[] sources) at System.Xml.Serialization.Compiler.Compile(Assembly parent, String ns, XmlSerializerCompilerParameters xmlParameters, Evidence evidence) at System.Xml.Serialization.TempAssembly.GenerateAssembly(XmlMapping[] xmlMappings, Type[] types, String defaultNamespace, Evidence evidence, XmlSerializerCompilerParameters parameters, Assembly assembly, Hashtable assemblies) at System.Xml.Serialization.TempAssembly..ctor(XmlMapping[] xmlMappings, Type[] types, String defaultNamespace, String location, Evidence evidence) at System.Xml.Serialization.XmlSerializer..ctor(Type type, String defaultNamespace) at Autodesk.Max.StateSets.Utilities.SerializableDictionary`2.ReadXml(XmlReader reader) at System.Xml.Serialization.XmlSerializationReader.ReadSerializable(IXmlSerializable serializable, Boolean wrappedAny) at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderConfiguration.Read10_Configuration(Boolean isNullable, Boolean checkType) at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderConfiguration.Read11_Configuration() --- End of inner exception stack trace --- at System.Xml.Serialization.XmlSerializer.Deserialize(XmlReader xmlReader, String encodingStyle, XmlDeserializationEvents events) at Ephere.Utilities.Serialization.Extensions.LoadXml[T](Stream stream, Type[] extraTypes) at Ephere.Utilities.Serialization.Extensions.LoadXml[T](String filePath) at Autodesk.Max.StateSets.Plugin.ReloadConfiguration() at Autodesk.Max.StateSets.Plugin.get_Configuration() at Autodesk.Max.StateSets.Utilities.Gui.ApplyColorScheme(Skin skin) at Autodesk.Max.StateSets.Plugin.Initialize(IGlobal global, ISynchronizeInvoke sync) at Autodesk.Max.Manager.RegisterLoadedPlugins()
