Cellular map help needed
  • Cellular map help needed
    Hi all
    How can I get the cell to just have 1 colour? We actually the cell is one colour but the division colour messes up so badly that some cells looks like it shares the colour of the divisions.
    Basically I want a single colour cellular tile with signle division colour. This seems easier said than done
    Kind Regards,
    Morne
    Play with your thresholds so you can make the blend as harsh as possible, or if that doesn't work make a mix map, choose your two colours for the base and cell, put your cellular map into an output map and put that into the mix map slot. Use the output curves in a really harsh s curve shape and you should be able to use it to make the cellular very clipped and get the result you want.
      Thanks the threshold worked good enough...
      Kind Regards,
      Morne
