Procedural Object XYZ cooridinates
  • #16
    Heh. forgot they had that one. Mostly useless for much with the limitations....tried using it for quite some time, but it was too limited.
    Railclone (pro) might be the most versatile and powerfull plugin I have used apart from VRay, once Itoo fix a few things and add support for using non-geometry in segments.
    I thought you guys were referring to some other free plugin that did the same.
    Signing out,
    Christian
