Is there a way (script) to select objects with similar amount of vertices...
  • Is there a way (script) to select objects with similar amount of vertices...
    ...as the selected object ?
    Regards
    Steve
    My Portfolio
    Code:
    select (for o in objects where (getPolygonCount o)[2] == (getPolygonCount $)[2] collect o)
    try this quick and dirty one
    www.hofer-krol.de
    Visualization | Animation | Compositing
      How similar?
      Colin Senner
        Should be pretty self explainatory. Change "thresholdPercent" to be how similar you need the objects to be, 0 = no deviation in vert count, 0.03 = 3% deviation in vert count.
        Code:
            local thresholdPercent = 0.01 -- Anything similar within 1% of the same vertices count will be selected
            local obj = GetCurrentSelection()
            if obj.count != 1 then (
                MessageBox "Please select one object."
                return false
            obj = obj[1]
            local numverts = (GetPolygonCount obj)[2]
            local lowNum, highNum
            local selectArray = #()
            format "numverts: %\n" numverts
            max create mode
            for o in objects do (
                lowNum = ceil (numVerts - (numverts * thresholdPercent))
                highNum = floor (numVerts + (numverts * thresholdPercent))
                if ((GetPolygonCount o)[2] >= lowNum) and ((GetPolygonCount o)[2] <= highNum) then
                    append selectArray o
            select selectArray
        Colin Senner
          Thanks a lot guys !
          Regards
          Steve
          My Portfolio
            Thanks again for these scripts. Is saving me a lot of time with this project
            Regards
            Steve
            My Portfolio
              no problem.
              Colin Senner
